String control not updating to latest values untill probe watch is used.
 I know that I'm receiving it in my arduino because I got two motors, each one works depending on the value sent by lab view when I get the "V" one motor starts working (this is the part that works well, once i switch to this case the "V" is sent right away and the motor starts working, but when i switch to the true part and try to update the value (setpoint) the other motor doesn't work until I open probe watch on the write buffer terminal of VISA write. the value(setpoint) is sent upon using probe watch or highlight mode, got no idea of whats goin on
Message 11 of 18
(1,373 Views)
 I know im receiving it in my arduino because i got two motors that depend on the value sent by labview, the "V is sent right away and one motor begins working but the other motor doesnt start till i open probe watch on the write buffer terminal of VISA write.
And yes I already try clicking outside the control and still not working,
what do you mean by false?
Message 12 of 18
(1,372 Views)
I have just never heard of LabVIEW or VISA functions working the way you are describing them.
Message 13 of 18
(1,365 Views)
Oh, I just meant that Update While Typing can be turned on or off (set to true or false). But it doesn't really matter since you have it off and I think that's the right call.
I really don't know what about setting a probe on that wire would be doing to make it work with the probe and not work without, sorry.
Some things you could try would be getting a program that can "spy" on your COM port or whatever and use that to see for sure what's really being sent. You could also try changing your string control to a constant (like the 'V') temporarily and see if it also works that way, just to find out if it's related to that.
Message 14 of 18
(1,357 Views)
Well, I will carry on searching for a way to make it work if I get to do it i will post it here, thanks guys.
I really appreciate the help
Message 15 of 18
(1,332 Views)
Accepted by AnthonX
Hi Anthon,
try to simplify your VI like this:
- No need to spin the loop as fast as possible when you don't want to communicate with your device.
- Do VISA Write/Read in serial…
- I used the select node instead of a case structure: due to dataflow there has to be a value send to the Arduino! You only need to check it's string content: use an indicator!
- Read the help for the InPlaceAndCoerce function to learn all its options!
Message 16 of 18
(1,329 Views)
thank you so much!! now one more question, do i need a waitms inside the while loop?
Message 17 of 18
(1,322 Views)
Hi Anthon,
No.
The VISARead will wait for messages of your device and so limit the iteration rate.
Message 18 of 18
(1,319 Views)
