String conversion only one past number
Why do I only get one past number?
STRING [XXXXX.XXXXXXXX] => FLOAT [XXXXX.X]
extended float to default did not help 😞
(3,674 Views)
Accepted by DerBachelor
your numeric indicator is set to display 6 digits of precision
(3,672 Views)
Correction: it is currently set up to display 6 Significant Digits.  And since you have 5 digits before the decimal point, you only get 1 digit displayed after the decimal point.  If you change to Digits of Precision, you will see more numbers after the decimal point.
So the data is actually correct, it is just how you are displaying it.
(3,669 Views)
Hahaha you got to  be kidding me Smiley LOL
Thanks a lot !
(3,663 Views)
Correct again, crossrulz.
(3,641 Views)
