String empty when project close and open
Hi everybody,
How can I set some text data into a string that will not be deleted when I will close and open my Labview project.
I have created a module and the text (which is a macro code to send to Excel) is cleared when I close my project... I have to paste the text code everytime..
Do you know what I am making wrong ?
Cheers
(3,414 Views)
Here is the VI.
(3,411 Views)
Accepted by Neercs
Hi Neercs,
some LabVIEW basics:
To set a default value of a control/indicator you usually fill in the value, followed by right-click on the FP element to select data operation -> set current value as default.
Or you use the edit menu entry "Set all current values as default".
Don't forget to save your VI after doing so…
(3,401 Views)
