String functions with array input - processing array of stings one function call
Thank you all for your reply.
I will leave this thread open, if anyone has other thoughts, please add here.
Thank you
Adarsh
CLA from 2014
Message 11 of 20
(1,971 Views)
ideas:
* See if you can get the array in a binary format
* See if you can get the array in a better formatted string
* Let us see what you are trying to format and see if we can improve the speed
Certified LabVIEW Architect
Message 12 of 20
(1,965 Views)
Can you post some example of data and your current code?
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 20
(1,937 Views)
@thols wrote:
ideas:
* see if you can reduce the number of strings generated
Former Certified LabVIEW Developer (CLD)
Currently using LabVIEW 2022
Message 14 of 20
(1,933 Views)
Couple people mentioned it already but you didn't reply to it so I'm not sure if you saw it. Have you tried this:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3QZCAY&l=en-US
Message 15 of 20
(1,925 Views)
ideas:
Thank you for your reply. Can you please share more details on this ?
Adarsh
CLA from 2014
Message 16 of 20
(1,890 Views)
I have seen this, but in the loop i have to take data converting decision based on the information in the previous packs. What does that mean is, i have shift the information extracted from earlier iterations to the upcoming iteration to data convert. How can we achieve this parallel loop? Any thoughts?
Best regards
Adarsh
CLA from 2014
Message 17 of 20
(1,888 Views)
Best regards
Adarsh
CLA from 2014
Then you seem to be doomed. Maybe you can buy an extremely powerful (and expensive) computer.
Since you did not provide the details of your processing, nobody can help you to improve it, if possible at all.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 18 of 20
(1,880 Views)
Hi Adarsha,
@AdarshaPakala wrote:
ideas:
To share more details you should provide an example VI with some example data - as has been requested so many times before…
Thoughts: provide an example VI with some example data to explain your conversion algorithm.
It definitely does NOT help when you provide information in tiny bits after days and weeks…
Message 19 of 20
(1,876 Views)
I'm very sorry, due to the privacy issue i can’t explain the parsing protocol.
I can't mimic the conversion complexity in a sample data and code without explaining the parsing logic.
It is my limitation.
Thank you all for the contribution.
Message 20 of 20
(1,851 Views)
