String globals keep resetting
I'm having a problem getting some string constants I have defined in a global variable file to stay saved in the file. I'm guessing I may be doing it incorrectly but I basically want these string variables to stay constant in the global file, right now I'm using a string control to define them. The problem with this is that these values get wiped everytime I close out Labview. I've attached my global VI.
Konrad
(4,329 Views)
If they clear you must have some function that writes to this file with empty values.
Attaching the Global doesn't help much, the main vi would be better. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,325 Views)
Accepted by niedk
Right click the global, select find all instances. Look through the find window and it should say if the different instances are read or write. Double click any that are "write" to see where they are being written to.
(4,314 Views)
The values in the global are only there until the global leaves memory.  This is true of all VIs, not just globals. If the values will never chnage, use Edit > Make Current Values Default on the Global 1.vi front panel.  Then save the VI.  If you need to change the values in yout main program, then you should write the data to a file before closing your program and read the data from the file as soon as the main program begins executing.
Lynn
(4,310 Views)
There may be a better way to do this, but off the top of my head, you could scrap the global if it's really read only. Create a cluster with all your constants and put it in a lvlib. Set it to private. Create a public read accessor for it to be used throughout yoru code. I guess you could stil change them locally in this case once a copy was gotten from the function, but you couldn't write back to the actual global instance.
(4,309 Views)
Lynn,
Thanks, this is what I was trying to do. I wanted to avoid extra definitions in my main vi itself.
Konrad
(4,306 Views)
