06-26-2019 03:10 PM
It's just a string... the entire system I'm talking about is a receiver for a signal. So it takes the signal's Y values, determines whether they're a binary 1 or 0 and appends a 1 or 0 to a binary string to give the resulting output. From there, I just want to take that string of binary numbers with no spaces and write that as ASCII text.
06-26-2019 03:12 PM
What's that "x 30" and the 4.x typecast? I'm not sure where to get them.
06-26-2019 03:19 PM
Here is another solution:
06-26-2019 03:21 PM
I think Darin's solution doesn't properly handle the line feed at the end of the string "0110100001100101011011000110110001101111001000000001010".
06-26-2019 04:07 PM
There is a typo, the correct string to have a newline at the end is
01101000011001010110110001101100011011110010000000001010
There is a subtlety that adds a null to odd length strings, I would fix it like this:
The x30 is the ascii value (hex 30, decimal 48) for '0', simply an integer constant.
You get the 4.x on Type Cast by using the right-click menu, it treats boolean arrays the old-fashioned way, ie. as bits.
