String
any help how can i find the number of times the letter "a" appears in the string what function i have to use. Thank you
Message 1 of 17
(4,651 Views)
Hi jiji,
Have you already opened the string functions palette? Have you tried any of those functions?
I would use a function which is able to replace a char and provide an output of the number of replacements…
Message 2 of 17
(4,643 Views)
this my attempt but I couldn't figure it out
Message 3 of 17
(4,617 Views)
Hi jiji,
unfortunately you decided to attach a VI in the newest LabVIEW version - which I cannot open (as indicated in my signature line)…
Hint: use Search&ReplaceString
Message 4 of 17
(4,602 Views)
You've got your wires connected wrong.  How to find it yourself:
  1. Click on the broken run arrow (or press Ctrl-L)
  2. When the error list shows up, double-click on the error
  3. Make sure context help is showing (Ctrl-H toggles it)
  4. Move the mouse over the offending function.
  5. In the context help window you can see what the connections are.  Bold labels indicate required connections.
Move those top 2 string wires up one.
Message 5 of 17
(4,592 Views)
hi
i attached a new example just to learn how to figure it out it is with old version i try with search replace string but not work. i enter 4 letter e in the string control but the indicator show 1. Thank u
Message 6 of 17
(4,575 Views)
@jiji_830 wrote:
hi
Pay attention to your wiring.  You've got the TRUE constant wired to the wrong input. If should be wired to "replace all"
Message 7 of 17
(4,570 Views)
thank u so much. if we want to generate the number of the words in the string we use same function ??
Message 8 of 17
(4,562 Views)
That should work, yes. Space is a good word separator to look for. 😉
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 17
(4,524 Views)
Yes, but simply searching for spaces won't work because it won't handle multiple spaces and it ignores other whitespace and it would be confused by leading/trailing whitespace.  Use this:
Note: Right-click on the "Search and Replace String" function to toggle "Regular Expression" mode,
Message 10 of 17
(4,496 Views)
