String
i try this solution but i got broken arrow even if i set the function to regular expression ????
Message 11 of 17
(1,604 Views)
You are making absolutely no effort to try to do it correctly, nor to find the problem yourself.
You repeatedly make the same error and you don't try to find it.
Pay attention to what I wrote in my previous posts.
Message 12 of 17
(1,599 Views)
actually i try different ways to solve this since yesterday but i couldn't figure it out. i am asking to learn i am  beginner in LabVIEW. Thank you
Message 13 of 17
(1,582 Views)
Hi jiji,
Which other ways did you try? Why didn't you show them in your VI?
On your last VI: after correcting just one wire it works for me. (Additionally I set the indicator to adapt its datatype to the wire source. No need for a DBL indicator on a blue I32 wire.)
Suggestion: open the context help in LabVIEW. Read the help for that string function. Even read the full help for that string function! Then do the same correction as I did to your VI…
So you took care of all those "Training resources" offered at the top of the LabVIEW board?
Message 14 of 17
(1,577 Views)
You remind me of my cow-orkers.  They "solve" problems by hacking away instead of making a proper effort to find a good solution.  I told you (in the 5th post of this thread) how to find problems like this.  You didn't do that.  I also told you to pay attention to your wiring.  You didn't do that either.  There's no point in trying to help you any further because you don't pay attention.
Message 15 of 17
(1,566 Views)
thank you all for your help.
Message 16 of 17
(1,561 Views)
 this is my attempt and it is working now. Thank you
Message 17 of 17
(1,557 Views)
