Structural Engineering
Shear Force Diagram (SFD) Generator ● Compute and plot shear force V(x) along a simply supported beam for point loads and UDLs. ● Allow user inputs for beam length, load magnitude, and position; display shear variation and reactions at supports. ● Concepts: Shear force distribution, load–shear relationship, sign convention.
I am farely new to LAB and I was thrown into the deep end with this assignment, all the ways I have thought of haven't worked, can anyone please help me
Message 1 of 9
(250 Views)
Hi zak,
what is your question?
(Do you want someone else do your job? Then you should offer payment in the JobOpenings board!)
Message 2 of 9
(241 Views)
I am a student looking for help I don't need someone to do my job, how will I learn?
Message 3 of 9
(235 Views)
Hi zak,
@thedumbestalive wrote:
how will I learn?
  1. Listen to your teacher.
  2. Read the course material.
  3. See all those TrainingResources offered at the top of the LabVIEW board.
  4. Play with the example VIs in the ExampleFinder (LabVIEW help menu)…
Message 4 of 9
(217 Views)
Look I didn't come here for scrutinity, if you dont want help it's okay, don't
Message 5 of 9
(205 Views)
Accepted by topic author thedumbestalive
Hi zak,
Look I didn't cone here for scrutinity, if you dont want help it's okay, don't
I did answer your question to my best knowledge.
We (the active forum members) are "just" voluntary contributors, writing messages on our spare time.
We are willing to help with specific questions.
We also help with homework duties, but don't provide them for free.
You did not ask for any specific problem, you did not show your VI (attempts), you just listed your homework requirements.
So when you want specific help you need to
  • provide your current VI
  • ask specific questions
When you provide VIs: most active members use older LabVIEW versions, while students often use the very latest version. Please downconvert your VI before attaching: most are happy with "LV2021 or older", I prefer LV2019…
Message 6 of 9
(194 Views)
I think you might have had a faulty google search. Are you sure you're asking a "LabVIEW" question?
LabVIEW is a graphical programming language used for test and automation, I wonder if you're looking for a different product and landed here by mistake.
How is any of this related to LabVIEW?
Message 7 of 9
(142 Views)
Dear "Dumbest",
     If you look at some of the posts in the LabVIEW Forum, you will find that GerdW is one of the most patient and helpful responders, gently trying to guide students (such as yourself) into learning LabVIEW.  If you have any experience with other programing languages, most of which are "text-based" (C++, Basic, Python), LabVIEW is very different, and you really need to pay attention to class, try making simple VIs to (say) count from 1 to 10 updating once/second (or other routines designed to test how the concepts you should be learning in class actually work).
     If all else fails (and you are unwilling to do your part), drop the class.
Bob Schor
Message 8 of 9
(111 Views)
I am farely new to LAB ...
What is "LAB"?
Can we assume you understand all the math behind the problem and you are just having difficulty to implement it in code?
How should the output look like (just numbers? Annotated graphics? etc.)
Message 9 of 9
(72 Views)
