Stumped on basic problem with floating point math
I can't figure this out!  It should be sooooo simple.
Here is the challenge:
I have an incoming time array.  For example:     0, 1, 2, 3, 4, 5, 6, 7, 8, 9
I want to scale this array by a constant (e.g. multiply by 0.1).  So the resulting array should be:     0.0, 0.1, 0.2, 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9
Then I want to calculate the difference between each and every subsequent element in the array.  In this example, the difference should 0.1 between every element.  But my comparison fails.
See the example below.  As far as I can see, the resulting boolean should always be TRUE.  But its not.
But if I remove the scaling operation, then it works ok!
http://www.medicollector.com
(3,226 Views)
Accepted by josborne
It has been awhile since smercurio has had a contribution to his retirement fund, but once again you have "discovered" that there is no exact binary representation for 0.1.
I'd use one of the current "almost equals" comparisons described here:
http://forums.ni.com/t5/LabVIEW/Darin-s-Weakly-Nugget-2-8-11/m-p/1444262
And vote for this if you haven't already:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/quot-Almost-Equal-quot-functions-for-Float-comparisons...
(3,213 Views)
Yeah, the little piggy was getting a little light.
josborne, you owe me a nickel. Smiley Very Happy
(3,191 Views)
Don't you mean two bits??? Smiley Very Happy
(3,180 Views)
