Showing results forĀ
Search instead forĀ
Did you mean:Ā
Sub vi not found error
when i run my vi....it gives error saying some of the sub vi are missing.I am now using labview 8.20 and the vi was intially done in labview 7.1. Any ideas or suggestions.
Message Edited by testdev on 01-09-2007 11:16 PM
(3,303 Views)
What's the name of the missing subVIs? Did you have any extra toolkits installed in 7.1?
(3,295 Views)
Merge testdata. vi is the sub vi missing.Thsi vi was created in labview 7.1....but we dont have labview 7.1 here, just 8.20
(3,292 Views)
Sorry, I thought this was on the same machine and you only upgraded the LabVIEW version. šŸ˜‰
If you transfer a VI to a different machine (independent of the LabVIEW version installed), you need to ensure that you include all subVIs. In LabVIEW 7.1, you would "save with options" and save as e.g. development distribution". This will include all subVIs.
(3,287 Views)
Thanks..i wil check  and see if that could be done.
(3,285 Views)
