SubPanels / Scrolling Containers
There's a part of my front panel that's much wider than the rest, and I'd like that small part to be scrollable.  I've been experimenting with SubPanels, but haven't found a way to use References to controls within the SubPanel VI.  Programmatically, the bit I want to scroll is very much part of the top-level VI - not well-suited to being a SubVI at all.
My question, essentially, is:
Is there a way to make a container that has no functionality other than the ability to scroll what's inside it?
(If not, how do you reference individual controls inside a SubPanel?)
Ian
(3,307 Views)
Hi Ian,
LV 8.x and up have panes, and are exactly what you describe. There is a one BlockDiagram but the front panel consist out of several parts!
Ton
My LabVIEW Ideas
(3,302 Views)
  just a quick example of using the panes programatically is attached below.
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(3,285 Views)
