SubPanels
Hello dear LabVIEW Users, would you please check this VI. On my PC it works how I want, but not an other one. Start the VI "SubPanels.vi" and try to create some new controls. Than change values of this controls. A dialog about new value should appear.
Thanks, Eugen
Message 1 of 18
(5,212 Views)
Hi Eugen,
i can create the sub panels and change the value, but there is no information about changing the value. I´m using LV8.5 on WinXP.
Mike
Message 2 of 18
(5,200 Views)
Thank you, I use lv8.0 , probably anything is changed on higher versions of LV. Can anybody say why it doesn't work?
Can anybody try it on lv8.0?
Thank you Mike
Message 3 of 18
(5,192 Views)
Hi Eugen,
i think you have to wait in your sub vi´s for a valid reference of the MainUE. i think there are time differences. if you check for a valid referece in a while loop, then i think it will work. i try it in my copy.
Another point is that you close the reference of the created vi directly after open it. Why??
Mike
Message Edited by MikeS81 on 01-30-2008 10:08 AM
Message 4 of 18
(5,186 Views)
Mike, I don't think it's a timing problem bekause I start the SubVI after setting value. I close the SubVI reference after starting them, because I don't need it. Is it wrong? Look the LV example (LV's example finder) "subpanels" . There the SubVI reference will be closed too.
Message 5 of 18
(5,176 Views)
Hi Eugen,
i have changed somthing in the booelan vi and in the main vi. Hope it helps. I have saved it for 8.0. Now it works on my pc.
Mike
Message Edited by MikeS81 on 01-30-2008 10:13 AM
Message 6 of 18
(5,175 Views)
Thank you Mike, how many iterations do you see in the boolean subpanel? I see 0.
Message 7 of 18
(5,171 Views)
Hi
yes you are right. i see 0, too. but that was the first point i have changed.
Mike
Message 8 of 18
(5,169 Views)
If you see 0 too, than it is not the timing problem of setting value. Do it work with string and numeric subVI too?
Message 9 of 18
(5,163 Views)
Hi Eugen,
now all three vi´s show the change value message. but i remove the close vi refnum function in the main vi.
Mike
Message 10 of 18
(5,160 Views)
