SubPanels
Hmm, it is realy funny now. Why does it work now? Did you check the example in LV's example finder? They close the SubVI reference directly after opening the SubVI too.
Message 11 of 18
(1,600 Views)
I confirm on LV8.5.  It works if close is removed.
Message 12 of 18
(1,579 Views)
Thank you too, could you try the example "subpanel" from LV's example finder.
Message 13 of 18
(1,578 Views)
I did check out 'subpanel viewer.vi'.  It is different from yours as only one runs at a time.  When a new one gets opened, it closes the previous one.  If you want to keep your structure, just array the open controls, then close them all on exit or when no longer needed.
Message 14 of 18
(1,556 Views)
Oh, sorry, I think Simple Subpanel.vi in example finder.
In this example is no communication between Main.vi and Sub.VI, but the reference will be closed after start.
And I think that I don't need the SubVI's reference after start of them and close it, say me please why I have not to do it?
Thank you, Eugen
Message Edited by Eugen Graf on 01-30-2008 12:20 PM
Message 15 of 18
(1,552 Views)
Hi Eugen,
are you sure that you connect the error cluster in the same order like shown in the example? If not it could be a timing problem. I unfortunately can´t check it now, because i´m not at work and so i have no LabView 8.x.
Mike
Message 16 of 18
(1,535 Views)
Hi Eugen,
now i have seen that the connection order is like shown in the example. As an other way i have deleted all references and replace it with direct invoke nodes for every sub panel, but that also don´t work. I think the solution with store the reference could be acceptable for you.
Mike
Message 17 of 18
(1,511 Views)
Ok, thank to all.
Message 18 of 18
(1,508 Views)
