SubVI dialog box
Hi people ,
I want to a subvi as a pop-up window and once the task is done , i wanna close it immediately leaving the values to the main.VI
Can you help me?
Boldness has genius, power and magic in it!'
Message 1 of 13
(6,453 Views)
Is this the same as your problem found here:http://forums.ni.com/t5/LabVIEW/dialog-box/m-p/2366450#M737025?
Show us what you have tried and where you are stuck.
Message 2 of 13
(6,440 Views)
You create a sub-vi with the "look" that you want for your dialog box, and any operator entries passed to output terminals. In the sub-vi you will probably need to have a while loop, with a way to exit, such as a "Yes" or "Continue" button. In the sub-vi's properties (right click on the sub-vi's icon) you can customize the appearance, removing the toolbar, etc., and in the execution have it set to run when opened.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 3 of 13
(6,438 Views)
Hi Cross ,
Ya you are right . Nearly same but i thought it would look  better if we have a pop-up menu till the user it tested the element.
so I made it in a Sub.VI.
I have called it from the Main.VI but the problem is i couldn able close it after it worl is done .
How to close the dialog box after the work is done and return to main.Vi
Message 4 of 13
(6,436 Views)
Can you post the VI?
Message 5 of 13
(6,429 Views)
Talking about the Main.VI????
Why dat is so important? (I really dono )
Message 6 of 13
(6,427 Views)
Your dialog VI.  I want to poke around your VI to see if I can figure out where you're stuck.
Message 7 of 13
(6,425 Views)
'This is my dialog VI. pls correct me if i didn any mistakes .
I am in a hurry doing to finish my thesis next week.
Message 8 of 13
(6,421 Views)
Do NOT use the Stop function.  That is like hitting the abort button.  You need to stop your loops naturally (using the termination terminal).  I would also change your sequence stucture into a state machine.  That way you can skip steps if needed.
And does it make sense for a dialog to call more dialog boxes?  That's one GUI I would not want to use.
Message 9 of 13
(6,415 Views)
Thanks Cross,
What do you mean by Termination terminal ? I didn get it . What will be the problem if we use nested dialog boxes ?
Message 10 of 13
(6,405 Views)
