how can I calculate the jacobian matrix please !!
(3,742 Views)
What does your normal matrix look like?  The jacobian is just a derivative of your matrix.  So if you take the derivative of your matrix using the position variables, you will simply get a new matrix that you can now just put in your values just like the original.
(3,732 Views)
thank you 🙂
(3,713 Views)
The jacobian is the matrix of all first order derivatives of a function with respect to another vector. What kind of function do you have? Are you looking for an analytical solution ir a numerical approximation?
For the math itself, all you need to do is follow wikipedia.
(3,704 Views)
