SubVI's of reentrant VI's - super basic question
Ahhh, the No Free Lunch law
Message 11 of 13
(525 Views)
That sums it up nicely.
Message 12 of 13
(520 Views)
wiebe@CARYA wrote:
@PaulOfElora wrote:
I like the in-lining approach, might get a little speed boost out of it.
At the expense of extra compile time.
And you'll loose the ability to debug the VI (probes, FP values, breakpoints, etc.).
You can't inline everything. VIs containing property nodes, invoke nodes, expression nodes (probably not a complete list) can't be inlined.
You can't put anything in a clone either. Pre-allocated clones don't allow application events, IIRC. A rarity, but recently ran into this.
Which is why we state that inlining is useful for small, concise, simple VIs where you will not need to do much debugging, but could use some extra potential optimizations.
Message 13 of 13
(514 Views)
