Subtract Function error
I use Labview Subtract Function and experiencing something that looks like failure. 1. Two numbers A = 0.15 and B = 0.1. 2. A-B = 0.05. 3. Check if A-B = 0.05 labview answer is no. 4. This is because the Subtract function has released a value that is 0.05 + 13.8778a. Are there others who have experienced this? Tips to fix? Please see attached labview code I use Labview 14.0.1f3 (32-bit)
(4,364 Views)
See real picture:
0.15 not 0.15 but 0.14999999...
su, if you want check A=B, you need check (A-B)<delta
(4,347 Views)
Accepted by G_K_R
To add to this, it's not a LabVIEW specific problem. Floating point errors are something you are going to have to take into consideration for any language. I linked a pretty good video explaining what is happening.
https://www.youtube.com/watch?v=PZRI1IfStY0
(4,338 Views)
PS.  Putting your about screen on your VI really doesn't help us.  And then putting a decoration box over your serial number to hide it really doesn't hide it.  We just need to move things to see the info you were hiding.
(4,328 Views)
Thanks for fast and good help 🙂
(4,318 Views)
