Successive CAN node and channel selection
We have 19 CAN nodes and up to 16 channels per node, all different. I would like to write a VI where I can firstly select the node out of a list of names and the list of channels comes up corresponding to that node out of which I can select a channel. This selected channel should connect to a channel in MAX.
My first problem is that I don`t know how to create a listbox (or something similar) which opens a new listbox (each one with different content) depending on the first selection and how to select an item out of the second listbox. Anybody an idea?
Message 1 of 1
(2,393 Views)
