daqmx read write in one task?
I hope this would be my last question.
I have one task with the DAQmx to read two values from sensors.Now I also want to write a value to another sensor.
It hasn't work to put the task together.
Should I make two tasks?How should I do this.
Thank you
(2,651 Views)
Hello Smoofo,
it is not possible to create one task for input and output values. You need two tasks. You can find input and output tasks under Labview/examples/Data acquisition/DAQmx functions.
Kind regards,
Elmar
(2,633 Views)
