Suggest the applicable cDAQ Chassis
In my application I am going to use one NI 9476, One 9264, One 9435, two 9485, two 9265 I/O modules please suggest me the appropriate Chassis that I can use for these modules.
Prashant
(2,388 Views)
Accepted by UPRR
Hi UPRR. You're going to use 7 DAQ modules for your application, correct?
In that case I would recommend you to get either:
1. NI cDAQ-9188 - https://www.ni.com/en-us/support/model.cdaq-9188.html - Ethernet Connectivity
2. NI cDAQ-9178 - https://www.ni.com/en-us/shop/model/cdaq-9178.html USB connectivity, BNC connections for external clocks and 32-bit counters built into the chassis.
Aldo H
Ingenieria de Aplicaciones
(2,385 Views)
