Suitable FPGA board
Which NI board is suitable to be used for image processing? The details that I want are:
  1. Language: Labview
  2. Applications : Image compression/processing (no need acquisition)
At this moment, I have NI MyRIO-1900. Is it suitable to be used for image processing?
Thank you
(3,236 Views)
See https://www.ni.com/en/shop/data-acquisition-and-control/add-ons-for-data-acquisition-and-control/wha...
What is your frame rate, type of processing, and size of each frame?
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(3,235 Views)
I used medical/DICOM images. Most of the images has maximum 550 KB of size.
I want to process the image using partitioning concept (N x N), where N= 4, 8, 24.
Type of processing is compression.
Thank You
(3,232 Views)
Did you look at the link posted above?
ALE Consultants
(3,219 Views)
Yes, I do. But, I don't want to acquire the image in real time.
Is it possible I use MyRIO + Vision Assistant for image compression?
Thank You
(3,214 Views)
Is there a reason you don't use your computer?  If you are just processing images that you already have stored isn't that what a graphics card is good for.
(3,186 Views)
Actually I want to process a medical image (dicom) not standard image (jpeg, png, etc) using FPGA board. My concern is to apply algorithms to the image pixel. I hope you understand what I try to said.
Thank You
(3,168 Views)
