Sum the values of the same elements of my table
I am doing a questionnaire on an interface.
I succeeded to get the values of my radio buttons and I put them in an array.
But I have to sum the values of the same elements of my table. But I can do it.
Can you please unblock me?
Thank you 🙂
Message 1 of 9
(2,328 Views)
Accepted by topic author Steph_2
Attached  code snippet to add similar
Message 2 of 9
(2,279 Views)
Hi PalanivelThiruvenkadam, Thanks you
Message 3 of 9
(2,264 Views)
Pazhanivel Thiruvenkadam, Thanks for your answer, Iwould like please to put in one table (in the table on sum values): Easy: the value of its sum Hard: the value of its sum Very Hard: the value of its sum Medium : the value of its sum How do I proceed please?
Message 4 of 9
(2,195 Views)
I want to put the sum in my table in the format:
Easy: value of sum
Hard: value of sum
Very easy: value of sum
Here is the vi
Message 5 of 9
(2,241 Views)
Few Points on your implementation.
1. If your array size remains same you can initialize with 3 Elements instead of 10.
2. Also Array Starts with 0 as Index and you are extracting Index Numbers from Label.Txt (Radio 1) so you can use -1 before replacing your data so that you will get your array starting from 0
Message 6 of 9
(2,232 Views)
I am very sorry but I didn't understand what to do. Sorry,
Can you show me please please?
Message 7 of 9
(2,228 Views)
Hello Steph 2,
Please find the attached code modified even my suggestions
Message 8 of 9
(2,224 Views)
Thanks you very much
Message 9 of 9
(2,218 Views)
