Sunshine Protection Act 2022
If this Act goes through, will the time shift or lack there off, get fixed with a simple Windows update or will we need some run-times updated for old LabVIEW applications? I'm wondering if the time shift is handled is LabVIEW or does it reply on the OS for that.
Amit
Message 1 of 15
(2,578 Views)
I am sure LabVIEW relies on the OS clock.
Message 2 of 15
(2,576 Views)
Only an insane person would handle time zones their own...
Message 3 of 15
(2,560 Views)
So are you suggesting that LabVIEW handles time zones itself or not?
Message 4 of 15
(2,547 Views)
So many tongue-in-cheek comments I could make here, but I'll be good.
I'm hoping they aren't.  That would be a horrible decision on NI's part, especially since the OS can do it all.
Message 5 of 15
(2,544 Views)
I would look very had into the LabVIEW settings and try to see if there is any place where one would enter time, date, timezone, and such. Then I would recommend giving up ... 😄
Message 6 of 15
(2,539 Views)
At least they are using an interesting EPOCH definition (Inherited from the classic Mac OS, of course).
Message 7 of 15
(2,531 Views)
LabVIEW uses the system clock and the system time zone settings.
So I don't believe anything should have to change as far as LabVIEW or your previous programs
=== Engineer Ambiguously ===
Message 8 of 15
(2,514 Views)
It would be so nice we didn't have the silly "spring forward/fall back" stuff because then I could use local time for filenames that contained timestamp data instead of UTC.
Bill
CLD
(Mid-Level minion.)
Message 9 of 15
(2,500 Views)
Just put up a sign: "this test station down for maintenance 1AM - 2AM Nov 6, 2022"
Message 10 of 15
(2,494 Views)
