03-21-2022 12:08 PM
If this Act goes through, will the time shift or lack there off, get fixed with a simple Windows update or will we need some run-times updated for old LabVIEW applications? I'm wondering if the time shift is handled is LabVIEW or does it reply on the OS for that.
Amit
03-21-2022 12:12 PM
I am sure LabVIEW relies on the OS clock.
03-21-2022 12:55 PM - edited 03-21-2022 12:58 PM
Only an insane person would handle time zones their own...
03-21-2022 01:16 PM
So are you suggesting that LabVIEW handles time zones itself or not?
03-21-2022 01:25 PM
So many tongue-in-cheek comments I could make here, but I'll be good.
I'm hoping they aren't. That would be a horrible decision on NI's part, especially since the OS can do it all.
03-21-2022 01:36 PM
I would look very had into the LabVIEW settings and try to see if there is any place where one would enter time, date, timezone, and such. Then I would recommend giving up ... 😄
03-21-2022 01:40 PM
At least they are using an interesting EPOCH definition (Inherited from the classic Mac OS, of course).
03-21-2022 02:28 PM
LabVIEW uses the system clock and the system time zone settings.
So I don't believe anything should have to change as far as LabVIEW or your previous programs
03-21-2022 03:07 PM
It would be so nice we didn't have the silly "spring forward/fall back" stuff because then I could use local time for filenames that contained timestamp data instead of UTC.
03-21-2022 03:14 PM
Just put up a sign: "this test station down for maintenance 1AM - 2AM Nov 6, 2022"
