Swept Sine Engine oft SVT and order analysis
I’ve got a problem by building up a vibration analysing test site. First I want to give you an overview over my test equipment. I am using a PXI RT Controller (PXI-8196) and the DSA-Card NI 4461, which is mounted in Slot 8 of the PXI-Chassis NI-1042. I have installed LabView 8.0.1, the Sound and Vibration Toolkit and the Order Analysing Toolkit.
I want to generate a sweeping sinus from 1000 Hz down to 50 Hz (with the Swept sine VI´s of Sound and Vibration Toolkit) on analogue output port a0 of the DSA-Card. The output signal is routed back to the ai0 port of the same device. The sweeping sinus is used for controlling a power amplifier which is connected to a non-rotating electrical machine. The current of the power amplifier creates a magnetic field, which excite vibrations of a special part in this machine. This vibrations are measured with a laser measurement system (doppler effect) and it delivers a voltage signal, which is proportional to  vibration velocity. This voltage is acquired with an sample rate up to 35 kHz on input port ai1 of the DSA-Card. With the answer of the laser measurement system, I’d like to compute the rms response level of the laser signal. Therefore I use the SVT Read Swept Sine RMS Level VI at the moment and it work actually fine. But I need more Information’s about the measured signal. I also want to compute the mechanical orders of this process, which are typically even multiples of the exciting electrical frequency. I want to get out the waveforms of every order (up to the 12th order) and create an order spectrum and the “Klirrfaktor”  which is similar to THD for each frequency.
I found out, that there is a toolkit for analysing orders, but only for rotating machines. So I installed the Order Analysing Toolkit and try to adapt it to the described problem above but I can’t solve the problem yet. Is there a way for adapting the block set of this toolkit for my problem? Especially I am interesting in how to rebuild a speed profile  for this case. Can I use the blocks of OAT in parallel and/or combination with the swept sine engine VI of the SVT?
I also want to collect the measured data. What is the best way to store it? Is an online computation of the requested parameters possible, or should the data first stream to disk and compute it subsequent to the measurement?  I hope you can give me some hint’s. Perhaps you can give me an example VI ?
(2,847 Views)
I would consider using your stimulus sinusoid - the swept sine as the tachometer.  Digitize it with an analog input channel, and use other analog input channels for your "vibration" measurement.  You can then use the analog tachometer VI to track the frequency of the swept sine, and then extract the order waveforms from the measured signal.  You can do this with the Gabor transforms, or with the OAT tools.
Let us know if this makes sense.
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(2,843 Views)
