does the DSC 8.2 module work ok with Labview 8.2b23 versión
Hi all, I have the Labview 8.2 20th, but when starting in the right hand lower corner there is a 82b23 versión. I would like to get the DSC 8.2 module but I´m no sure if that version of Labview is ok for this DSC module.
Could anyone confirm this question?
Thanks in advance
(3,984 Views)
Hi Icaro,
I don't know where and why you can see the version number 8.2b23, but it should be a simple sub-version number, so your Labview 8.2 is surely compatible with all modules and toolkits.
Tell me if you will have some problem installing and using Labview and send me the screenshot of the labview panel.
Regards.
MarcoC
(3,961 Views)
See this. It's bad enough that some people are getting unlicensed versions of LabVIEW but then they also expect support.Smiley Mad
Message Edited by Dennis Knutson on 10-26-2006 06:41 AM
(3,945 Views)
