01-13-2017 06:39 AM
Hey,
I'm trying to use 'Switch - Scanning with a DMM - Handshaking' in lv2016 but obtain time out on DMM R measurement Fetch multi point or obtain 'You cannot make an explicit connection to a configuration channel' when configurating 2533 with a column in Reserved for routing channels.
Is there a labview user manual (software/api use) for 2533 NI-Switch ? e.g. Regarding Load Channels, Source Channels, Reserved For Routing Channels... etc. ? thx
Solved! Go to Solution.
01-13-2017 06:59 AM
Sorry, it's solved. I simulated the 2533 mux and had 4065 DMM real. I now simulated both and it works.
