Switch between frontpanel of MainVI and frontpanel of SubVI
Everybody,
I want to Switch between frontpanel of MainVI and frontpanel of SubVI.Detailedly,when i call the subVI in the MainVI,hide frontpanel of the MainVI,And show the frontpanel of the MainVI when i close the subVI.Like LV.I have a unsuccessful example.
Using LabVIEW 8.0.0 on Windows XP
(3,120 Views)
Hello Richar,
instead of 'FP.Open' you can use the property 'FP.State' to hide the main vi. You only have to set this property in the subvi. To show the subVi you have to set the properties in the vi properties dialog (right click on icon): window appearance-> show when called & close afterwards.
(3,113 Views)
Thank youSmiley Very Happy
(3,101 Views)
