Switch on timer
I would like to generate a sinusoidal waveform source from DAQ Assistant 2 sec after the VI is called. The source will then use to run a piezoceramic stack. How do I turn on the source automatically using timer after 2 sec?
Thank you.
(3,400 Views)
Accepted by CYTeoh
Add a Time Delay Function before calling your DAQ Assistant.
Wiring of Error out from Time Delay to Error in of your DAQ Assistant ensures your timing.
Because DAQ Assistant can only start when Time Delay has finished (Dataflow principle)
regards
adigator
(3,391 Views)
Thanks!!
That's what I need.
Your help is much appreciated.
CYTeoh
(3,382 Views)
