Switching Front panel background
In an application i did i added some brushed metal as tab background. I just drag'n'dropped the .jpg directly to the tab control. Doesn't it work for you?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 17
(1,787 Views)
Yamaeda, COuld you save that for previous version LV 9.0? Thanks!
ALso, I tried the tab control and inserted the picture on the 2D Picture control in the first tab and my second tab will be results tab. My question is why doesn't my image adjust to 2D control size? My picture is very high resolution, so the bottom part gets cut off. THanks!
I may not be perfect, but I'm all I got!
Message 12 of 17
(1,781 Views)
LiaLiu, I tried your example. It doesnt work.
Message 13 of 17
(1,776 Views)
Hi VeeJay,
I've attached the VI that saved to LabVIEW 2009.
It should work, I've checked on my PC.
Message 14 of 17
(1,773 Views)
2009 attached
/Y
Qestit Systems
Message 15 of 17
(1,749 Views)
Thanks! This is what I was looking for. Although, I don't see a 2D pciture control on the block dioagram. how did you add the awesome picture? And make the tab disappear?
Message 16 of 17
(1,740 Views)
The picture is simply drag'n' dropped from the windows explorer onto the tab control.
The tab control is a Classic tab control.
R-click the tabs to select "Visibility".
Use the coloring tool to paint area and borders Transparant.
It's an easy solution that works for many applications. 🙂
/Y
Qestit Systems
Message 17 of 17
(1,725 Views)
