Switching a relay on/off using DAQ asiistant
Hello, I am trying to create a VI that switches my relay on for a specific amount of time and then off for sometime, on repeat. switching it on works but i don't know how to switch it off and repeat. i have attached my VI, please do tell me what alteration is necessary to make it work.
Thankyou
(2,979 Views)
Hi Doha,
To switch ON you send a TRUE constant. Which constant is needed to switch OFF?
Hint: to repeat a certain task it would help to use some kind of "loop" construct…
No, you don't!
It's only an image - we cannot debug images using LabVIEW!
(2,977 Views)
I know i need to put a false constant but I'm not sure how to connect it.
I have attached my VI.
(2,969 Views)
Accepted by topic author Doha_h
Hi Doha,
Then you should takes all those (free) training resources offered in the header of this LabVIEW board!
To give an idea:
(2,965 Views)
can you send me the link for the free training resources ?
thanks a lot for your help
(2,933 Views)
Hi Doha,
see here: right at the top you will find "training resources"!
(2,927 Views)
