Switching between 2 string values
This is probably a trivial question, but how do I switch between 2 string values to be sent to one input terminal of a larger concatonated string function. The values need to be changed every 100ms or so.
mhaque
Message 1 of 11
(6,776 Views)
Accepted by mhaque
You're right, it's trivial. Smiley Wink
Balze
P.S.: Attachment VI LV2009
Message 2 of 11
(6,768 Views)
Why so complicated??? 😮
You can do this particular string manipulation in a single atomic operation using "Append True/False String" 😄
Message 3 of 11
(6,751 Views)
That's why you are a "knight of NI" and a "Labview Champion" and I'm not  . Smiley Sad
Smiley Wink
Message 4 of 11
(6,744 Views)
Is there a time delay on this VI or is the switching immediate?
If there is a time delay, does it correspond to the whole while loop?
mhaque
Message 5 of 11
(6,740 Views)
No,
this is (nearly) the same: (Altenbachs is single VI version)
Message 6 of 11
(6,731 Views)
The switching happens as soon as the computation completes. There is no data dependency to the wait function, thus both (the wait and the computation of the string) execute in parallel.
For each new iteration, the string will thus update within nanoseconds while the wait prevents going to the next iteration until it has completed.
Message 7 of 11
(6,726 Views)
Smiley Wink
Actually, I was specifically only commeting on your suggestions. The original problem description was:
"...be sent to one input terminal of a larger concatonated string function..."
If if this switchable string goes somewhere in the middle of a huge concatenate string function, you solution might actually be more appropriate. 😄
Message 8 of 11
(6,710 Views)
Hi
This VI works, but what does the 200 and the 100 signify?
Sometimes my main VI hangs I believe it could be related to this VI.
mhaque
Message 9 of 11
(6,442 Views)
you are right altenbach with the "append true/false string" I can only put the strings to be switched at the end. Since I need it to be in the beginning Balze's solutions gets the job done. However what does the 200 before the "qoutient and remainder" function represent as well as the 100 before the"greater than equal to" function? Are they the time delay? I'm quite confused.
Mhaque
Message 10 of 11
(6,436 Views)
