Synchronization between NI 9862 and NI 9205 in Cdaq 9189 : possible or not ?
Hello
I would like your help to answer a question relating to the synchronization of data on the CAN Bus (NI 9862) and an AI module NI 9205.
Materials: (CDAQ 9189, NI 9862, NI 9205)
The two NI 9862 and NI 9205 modules are connected to the CDAQ 9189:
Is it therefore possible to synchronize the analog measurement voices with the data from the CAN bus.
For information : The sampling frequency is about 100 Hz (for each sensor)
Thank you in advance for your reaction.
Message 1 of 1
(898 Views)
