Running CRC to the signals sent from LabVIEW NXG 5.0 using a USRP
    I am currently running an experiment where I send a 916.8MHz BPSK signal from a USRP using LabVIEW NXG 5.0. This signal will be received by a pair of Software Defined Radios controlled by MATLAB.
    However, I’m not sure if all the BPSK signals sent from the USRP are received by the SDRs. So, I am trying to do a CRC test against the BPSK signals received, but I’m not sure how to do this.
    I tried using a LabVIEW NXG function called “MLS sequence waveform” where I supposedly could select the maximum number of digits for the binary message before it cycles back to the first digit, but I can’t figure out WHAT the actual binary message is. And because I can’t see what the binary message is, I can’t tell MATLAB what message they are supposed to find.
    If anyone can give me any advice, that will be appreciated!!
P.S. some additional information/details:
  1. I have barely touched LabVIEW before.
  2. The signal source I am using is something I found from my lab’s database. So, I’m not sure if the signal source is even working correctly.
  3. The reason I am suspecting a bit loss in the signal is because there is a filter at the end of the program(diagram), which apparently causes bit loss in a BPSK signal. Not sure why this happens at the moment, but I am trying to see if that is what’s happening in this experiment.
  4. The Signals are sent from the USRP to the SDRs via SMA cables (co-axial cables), not wireless.
  6. I'm trying to upload the entire source code(diagram?) as well, but the file is too big to be uploaded.
Message 1 of 1
(1,050 Views)
