sequencing an MFC and a pneumatic valve
Hey,
I want to control a MFC and a pneumatic valve in labview
1 The valve should remain close(false boolean value) when the MFC  is set to 0
2 when MFC is set to a non-zero value, the valve should open (true boolean value) 500 ms before the the mfc gets set to that point
3 When MFC is set to 0 from a non-zero value, The MFC should get the 0 value 500 ms before the valve gets the false boolean value.
Any solutions?
(1,180 Views)
Predict the future? I'm looking forward for a solution 🙂
(1,171 Views)
