Try to look at RTSI. The PCI-1200 doesn't have that connector though. If you
want, you can try to do it by software. If you want high-speed
synchronisation, you HAVE to use RTSI, but then you have to look at other
cards. PLease call your local NI Office for more information... they won't
hurt you!
Koen Hoogstoel
National Instruments Belgium
Antony Wangsanata wrote in message
news:387e8f41@newsgroups.ni.com...
> DAQ Cards being used:
> - PCI-1200 (2 DIO lines used for transmitting digital signals)
> - 6023E (2 DIO lines used for receiving digital signals)
> Problem:
> I would like to send and receive digital data continuously at the same
rate.
> I don't know if synchronization has to be done in software, or there can
> be some sort of
trigger/clock signal to use between the two DAQ Cards.
> Please Help. Thanks
