Synchronization three actuator with three sensors
Hi all,
Actually, i am trying to actuate my system in three differnt direction and measuring the frequency by using three capacitive sensors. the synchronization is an important issue in my project. I need to actuate (vibrate) the three actuators simultaneously and measuring the resonant frequency . however, i am facing problem with synchronization . I am trying to run the code but give me an error as can be seen in attached file.
I am using NI cDAQ-9172 to acquire and send the signals.
Could you please help me at this point.
Message 1 of 13
(3,510 Views)
Sorry I forgot to attach the image of the error
Message 2 of 13
(3,503 Views)
any help would be appreciated
Spoiler
Smiley Very Happy
Message 3 of 13
(3,470 Views)
Hi engkhalid,
What C-Series modules are you using in your chassis?
It seems this error is more linked with a hardware issue - it may be worthwhile checking through the steps in this KB:
http://digital.ni.com/public.nsf/allkb/61371556441E5FF68625730600775934
Message 4 of 13
(3,430 Views)
Hi aransena,
Actually, I have solved this proble by reset the Daqmx and it is working. However, I am facing another problem. I need to make the Dc voltage active while the code is running. I have located the generating signal inside the loop but doesnot work. could you please help me at this point.
Khalid
Message 5 of 13
(3,424 Views)
Hi
I have place the generiating siginal with DAQ.mx write inside the loop, but still have an error. I have attached the Vi file .  Could you plase help at this point.
Khalid
Message 6 of 13
(3,417 Views)
Is it the same error as before, or a new error which is appearing?
Message 7 of 13
(3,394 Views)
 it is new error.
Khalid
Message 8 of 13
(3,381 Views)
Hi Khalid,
Please elaborate on the error you are encountering so I can give you specific help.
Having looked at your code, I believe one issue may be that you're attempting to start your waveform output with an empty buffer (i.e. the first time you run the program and want to Start the task, you must first use a DAQmx write).
See this example for further details on this possible solution, but please do elaborate on the issue if this does not resolve the error: http://www.ni.com/example/29872/en/
Message 9 of 13
(3,377 Views)
Hi arana,
I am trying to make the dc voltage active. I have tried to locate the the generating signal inside the loop but it does not work.
Khalid
Message 10 of 13
(3,375 Views)
