02-24-2014 07:19 AM
Hi Khalid,
Could you post your vi which you are having issues with so I can get a better idea of what the issue might be please?
02-25-2014 02:43 AM
Hi arans,
I have attached the VI However, the problem that i am trying to solve is about the Daq max.read does not acquire data and also does not generate the data. I have add the PID control system to tune the resonant frequency with changing the DC voltage.
Thank you
03-05-2014 04:37 AM - edited 03-05-2014 04:37 AM
Hi there,
I think if you essentially want to synchronize your AO and AI tasks (which appears to be where the issues are occuring?) it should be possible to modify this example to your application:
It's written for DAQmx Base; however the triggering concept should still be applicable if you set up this triggering structure in your code using DAQmx VI's and the same trigger references.
