Context:
I want to acquire 32 bits of data with a 6533 in RT at a frequency of 1,25 kHz or 2,5 kHz. These data and clock are generated by an external FPGA with a correct timing for the 6533.
I have configured the data acquisition in Pattern I/O with the clock entering the REQ pin of the 6533.
The problem is that the DIO Read function that I use in the Time Critical loop seems to prevent any other task (TC as well as normal priority tasks) to be done when I launch the .vi. So that I lose the PXI control and have to reboot the system.
To avoid that, I have tried to use DAQ occurrences, but the Wait On Occurrence function seems to be limited to a 1 ms period.
Are DAQ occurrences compati
ble with RT, are they a good solution to my problem, and if yes, how to configure it to get a synchronized frequency ?
Configuration:
PXI 1000B + PXI 8145RT + PXI 6533 + PXI 6052E + PXI 8420
LV 6.1 RT
NI DAQ 6.9.2
Thanks in advance for your help.
