System Exec VI not generating Standard output or File
@linu95k wrote:
Is there a work around this?
The easiest would be to see if their is a 32-bit pnputil and placing it in SysWOW64. 😁
Or to go with one of the other utilities you originally named.
Or move to 64-bit LabVIEW.
Anything else gets quickly very messy.
Rolf Kalbermatter  My Blog
Message 11 of 14
(1,770 Views)
Accepted by linu95k
The officially microsoft-approved solution is to use
%WINDIR%\sysnative\pnputil.exe
as the executable, documented here: https://docs.microsoft.com/en-us/windows/win32/winprog64/file-system-redirector.
Message 12 of 14
(1,762 Views)
Thank you so much this works great.
Message 13 of 14
(1,758 Views)
Thanks from me as well, was pulling my hair out for the exact same issue!
Message 14 of 14
(1,688 Views)
