System Exec.vi do not execute a command with correct syntax. "Error 2 occurred at System Exec.vi"
Hello all!!
I`m trying to execute a command to system using the System Exec.vi
The command is:
start /max chrome "http://www.ford.com"
This command works proprely when I run it directly from Prompt command but when using LabVIEW through System Exec.vi it gives the error:
Error 2 occurred at System Exec.vi. Command was "start /max iexplore "http://www.google.com"
Possible reason(s):
LabVIEW: Memory is full.
NI-488: No Listeners on the GPIB.
Block diagram image:
someone could help me with that?
Message 1 of 9
(12,012 Views)
Accepted by clebermarques
Prepend cmd /c, i.e. your command line should look like this:
cmd /c start /max chrome "http://www.ford.com"
Message 2 of 9
(12,000 Views)
Error 2 is misleading. System Exec.vi simply does not find the EXE file you reference.
Passing 'C:\Program Files (x86)\Internet Explorer\iexplore.exe http://www.google.com' as command line to System Exec.vi works on my system.
EDIT: Sorry, cannot remove that stupid hyperlink as Lithium seems to automatically add the hyperlink once posting.
Norbert
Expert: Geometry
Message 3 of 9
(11,990 Views)
Norbert_B escreveu:
Tks Norbert. The disadvantage of your solution is about compatibility and repeatability to operational systems with language different of english without edit the code just befause you have specified the absolute (full) path to the program.
However, tks for replying!
Message 4 of 9
(11,969 Views)
@clebermarques wrote:
[...] operational systems with language different to english without changes in the code once you have specified the absolute (full) path to the program.
Point taken. However, as of Windows 7, the paths for installed software should always be english. The OS only changes indication in the file explorer if language setting is not english.
But you are correct that dan_u's solution is far better.
Norbert
Expert: Geometry
Message 5 of 9
(11,959 Views)
Hi marques,
AFAIK the command shell only knows about English names of the standard folders:
The Explorer shows German folder names while DIR in the command shell gives English folder names…
Message 6 of 9
(11,957 Views)
And in addition to GerdWs first reply it is useful to have a look on all "cmd.exe"- options with
"cmd /?" in the console- window.
Greets, Dave
Message 7 of 9
(11,945 Views)
Norbert_B escreveu:
You can use %Programfiles(x86)%\Internet Explorer\iexplore.exe  to use the current system path.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 9
(11,922 Views)
FYI - I googled "labview error 2 system exec" and this was the very first hit:
http://digital.ni.com/public.nsf/allkb/EA1600EBA422E97286256AA20073C616
You could've saved ten minutes by asking google first.  😉
Bill
CLD
(Mid-Level minion.)
Message 9 of 9
(11,905 Views)
