System Exec
I am having trouble with the System Exec.vi in my stand alone application. Here is the scenario:
I am using System Exec.vi with a command "devcon find =ports" to find all of the connected COM ports. When I run the program within LabVIEW, I am able to see all of my COM ports. It works great.
When I run the application on my computer, it does not error out. No COM ports are returned in the output.
I then right-click on the application and select "run as administrator". The program runs and outputs the same COM ports I see when I run the program in LabVIEW.
Is there a way to work around this issue? I read into manifest files but was not able to completely understand how to do what it was asking. Even then, did not know if it would fix my problem. Manifests seem to ask the user for admin right access rather than running the program as an admin...
Thank you in advance for your help.
CLD Certified 2014
Message 1 of 9
(5,486 Views)
Hi ADrexel,
what about using VISAFindResource to find all COM ports?
Message 2 of 9
(5,481 Views)
Hi GerdW,
When using VISAFindResource, I cannot see the type of connection i.e. rs232 to usb adapter manufacturer to identify the correct connection.
CLD Certified 2014
Message 3 of 9
(5,477 Views)
What chipset?  ftdi, SiLabs or prolific?
The system API should be able to return the vendor id (VID) for any PnP actually connected.  The System registery keys would be able to get any serenum HKEYs reserved for disconnected VCPs.  Either way System exe.vi is not the best means to get the info you want.... dig just a bit deeper into the OS
Message 4 of 9
(5,466 Views)
Prolific.
CLD Certified 2014
Message 5 of 9
(5,463 Views)
@ADrexelDragon wrote:
Prolific.
Errr
I was afraid of that... thats  the one I have had the least problems with so its idiosyncraties are less known to me.   Try the system hardware API.  The COM ports VID should identify the VCPs that are from Prolific
Message 6 of 9
(5,457 Views)
I'll look up system hardware API and try to understand that and report back with any updates. Thank you!
CLD Certified 2014
Message 7 of 9
(5,454 Views)
Hi Jeff,
I am unable to find information regarding this "System API" that you speak of. Is this in the Instrument I/O tab in the palette?capture1.png
CLD Certified 2014
Message 8 of 9
(5,433 Views)
Accepted by topic author ADrexelDragon
Thank you for your help!
CLD Certified 2014
Message 9 of 9
(5,414 Views)
