TCP Data Stream to Pi
Hello all, I currently have a VI that sends some data to a raspberry PI and I do not believe it is the best way to do it, but its working.
RT_TCP.VI     -> Works fine but uses two ports
RT_TCP_SingePort.Vi     -> Does not work how I would like. It currently sends repeated timestamps OR messes up the sampling.
I have thought about putting everything into a single loop but would like some guidance first.
(752 Views)
You talk about "single port" and "single loop" and it is not clear at all what you are doing. Show us some code and explain what's running on the pi.
(741 Views)
I attached all of this in previous post, but I guess it did not work.
(735 Views)
Your attachment is missing the lvproj and lots of subVI.
https://tmesystems.net/
(692 Views)
(662 Views)
