TCP/IP C# with Labview
hello everyone,
At the moment i'm trying to send a String from C# to Labview however Labview gets an empty string he does notice that something is send as the listener simply replies and i've checked within C# itself and there i get the right format of string back i'm not sure what i'm doing wrong i'll attach my projects so you guys can have a look
code sample as i can't attach the .cs:
// Create a TCP/IP socket.
Socket client = new Socket(AddressFamily.InterNetwork,
SocketType.Stream, ProtocolType.Tcp);
try
   client.Connect("127.0.0.1", 8222);
catch (Exception ex)
     MessageBox.Show(ex.ToString());
     byte[] outStream = new byte[10025];
     outStream = Encoding.ASCII.GetBytes("je krijgt iets terug");
     client.Send(outStream);
     MessageBox.Show("data send");
end of sample.
thanks in advance,
Rinus1993
Message 1 of 12
(7,608 Views)
did you try to send the String using one of  the LabVIEW shipped examples?
The TCP/IP shipped examples are located in :
Program Files\National Instruments\LabVIEW XXXX\examples\comm\TCP.llb\Data Server.vi
Where XXXX is your LabVIEW version
Message 2 of 12
(7,600 Views)
well yeah and that works i think the big problem is that C# sends over byte arrays while Labview doesn't or at least some other encoding is used...
Message 3 of 12
(7,596 Views)
because when i put a breakpoint he does come into the read function so he does hear stuff he just has absolutely no clue what he hears and i'm using labview 2011
Message 4 of 12
(7,594 Views)
I think you have to read the bytes header then message
Message 5 of 12
(7,587 Views)
what you mean by that is this in C# or in Labview? because i tried type casting but Labview's pretty convinced his output is a string
Message 6 of 12
(7,585 Views)
I mean in LabVIEW
Using TCP Read VI if nothing is connected to the Bytes to Read, the function will not report a timeout error.
Message 7 of 12
(7,580 Views)
The default value for Bytes to Read is 0, so the VI is looking for 0 bytes and is not throwing an error because if there are no bytes coming in, it is reading the expected value.
Message 8 of 12
(7,579 Views)
ah ok like that so you think it should work if i define a constant 0 bytes on the read function i indeed didn't connect that
Message 9 of 12
(7,576 Views)
Accepted by topic author Rinus1993
No.
The Bytes to Read should be set to a large number because the function will read FROM the number of bytes specified at Bytes to Read.
Try with 10025 bytes
Message 10 of 12
(7,570 Views)
