TCP/IP PROGRAM ERROR
Idk why you are using a que, but it seems a bit complicated. Attached is some code i wrote for you to reference. It pulls the first row of a spreadsheet, attaches the ms time to the array and sends via TCP/IP. Hope this helps.
Message 11 of 18
(1,282 Views)
i am going to do it and i will say you if it works good, thanks fernando!!
i am using labview 2009!
thanks!
Message 12 of 18
(1,275 Views)
hi! fernando nad tom,doing the same example as fenando, i have an error,
error 63 ocurred at tcp open conection...serial port receive buffer overflow...
whats that...i don't understand it...
Message 13 of 18
(1,267 Views)
i attaached my origram , ithink is better done than the last one...
but is still with an error, error 56...
thanks!
Message 14 of 18
(1,258 Views)
Give this a try.
Follow the instructions on the front panel of simple data server.vi
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 15 of 18
(1,254 Views)
can you put in the format of labview 2009 please?
Message 16 of 18
(1,251 Views)
Sorry, here.
Message 17 of 18
(1,240 Views)
i tried it and it works good!
Message 18 of 18
(1,223 Views)
