TCP comm with multiple instruments
Is the data that you are reading distinct messages or simply streams? As Dan mentioned you can push data you have read from the handler to the master. If they are distinct messages do this whenever you have read a complete message. If you wnat the master to request the data the handler can buffer the current data and simply respond to the master's request. The handler would have parallel loops in it. One would strickly read the data. The other would be to respond to messages from the master. The only delay a WAIT would induce would be instaneous when a request for data is received while the data is actually in the process of being received.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 21 of 32
(1,061 Views)
I have written a mutli-byte termination reader in the past. Essentially I read a character at a time and do a regular expression lookup on the complete buffer. When I get a match I send that chunk to wherever it needs to go. Other wise I keep building up the buffer. With small messages there really isn't a huge perfromance problem. If your messages are extremely large than you may run into some issues.
Mark Yedinak
LabVIEW Champion
Message 22 of 32
(1,060 Views)
TCP implements a packet seq number to ensre that nothing is dropped and everything is in order.
But Ben, the IMMEDIATE mode of TCP-READ says that it returns whatever bytes have been received at the timeout point.
I'm concerned that my TCP READ call (timeout = 0) would occur when the message is halfway thru.
You're suggesting that that can't happen, because partial messages don't get thru, I suppose that makes sense.
But I can't guarantee what the instrument does in any case, so this might be a dead end.
Steve Bird
Culverson.com
LinkedIn
Message 23 of 32
(1,059 Views)
No, TCP has no concept of YOUR messages. It only knows about its data stream. It will guarantee that you get the data in the same order it was sent. If a packet is lost you will get all of the data received up to that point even if data past that has been received. However, as I stated it has no idea what your messages look like and doesn't guarnatee that your read will give you a complete message.
Mark Yedinak
LabVIEW Champion
Message 24 of 32
(1,057 Views)
Distinct messages.  This instrument isn't smart enough to just send data,data,data.  It's all a question-answer-Q-A-Q-A...
That sounds feasible.
--- that doubles the amount of load on the thread scheduler.
Steve Bird
Culverson.com
LinkedIn
Message 25 of 32
(1,056 Views)
--- That's exactly the idea I came in with.  I've done it before, but in connection with a single RS232 instrument, and performance wasn't an issue.
My messages will be < 200 bytes.
Steve Bird
Culverson.com
LinkedIn
Message 26 of 32
(1,061 Views)
Here is an example using VISA. It will work with TCP primatives as well.
Mark Yedinak
LabVIEW Champion
Message 27 of 32
(1,058 Views)
I mentioned before that I did a test:
TCP WRITE (request)
for I = 0 to 250
  Nbytes = TCP READ (immediate, Timeout = 0)
Nbytes came back with the message when I was 200-210 or so.
I have changed that to:
TCP WRITE (request)
for I = 0 to 250
  N = TCP READ (immediate, Timeout = 0)
  Buffer.Concat (Bytes Read)
  Before,After,Where = Match Pattern(Buffer, LF)
  if Where = -1  // not found
    Buffer = Before
  else
    Buffer = After
    Message = Before
  end if
(error checking not shown, but tested).
... and the message comes in at I = 140--150, meaning that the loop slowed down (only 150 loops in the same time as 200 before), but that is still PLENTY adequate , I think (crosses fingers).
 And there is no waiting.
I like the elegance of the spawned handlers idea, but I don't see a performance benefit, so I think I'll try the idea I started with.
Thanks to all who contributed.
Steve Bird
Culverson.com
LinkedIn
Message 28 of 32
(1,045 Views)
The big factor that triggers the spawned handlers in my apps is a desire to ensure no single widget hangs the rest.
Have fun!
Ben
Message 29 of 32
(1,034 Views)
Although not exactly the same, the similarity to this code caught my attention.
Ben
Message 30 of 32
(1,032 Views)
