TCP communication and Remote Panel programming
I had installed the LabVIEW runtime Engine and tried to web publize my application. I am able to do that and see the preview and also run the program from here. After that when I give the URL and try to access the web page, on the same computer( server), I am getting the following error:
'Requested VI is not loaded into memory on the server computer'.
Also the URL link gives a ' page not displayed' on any other computer in the server domain'.  Please advice,
Also whats the difference between DSC Run-Time Engine and Run-TIme Engine. I have LabVIEW 7.1, do I need the DSC version to control my application remotely.
Thanks in advance,
D
Message 11 of 12
(759 Views)
Hi Matt,
Thanks for pointing that out!  When you run the installer, it actually says that it's installing the LabVIEW 8.0 Run-Time so I am fairly certain that the webpage is inaccurate.  I will point this out to the appropriate people 🙂
Megan B.
Message 12 of 12
(642 Views)
