TCP communicator active & passive cannot communicate with Graph
I send and receive data from TCP Communicator Active & Passive.
I modify it and now can show data(given fixed) and graph.
My Active part can work. But I cannot send to Passive...
confused ha..hahahs...
Message 1 of 13
(6,012 Views)
Can you identify what is the difference between these two VIs, and what is the error or unexpected result you found?
Message 2 of 13
(5,991 Views)
Hi KateB,
the difference is the top left side the TCP Listen and TCP open collection.
what i respect is that both of the VI will recieve the data and graph.
Now can only recieve one side from Passive.vi.
regards,
Elsa
Message 3 of 13
(5,983 Views)
sorry,,
what i respect is not only recieve but can send data and graph also...
regards,
Message 4 of 13
(5,980 Views)
TCP listen will wait for connection from other TCP session.
If you don't have other sessions, it doesn't work.
Please refer to data server.vi and data client.vi in Help>>Find Examples on how to program it.
BTW, if you don't wish to send data across machine, you should use queue instead of TCP.
Message 5 of 13
(5,969 Views)
Hi, KateB What do u mean that TCP listen will wait for connection from other TCP session? Data server .vi and data client.vi can send one direction, which means data server can send data to data client, but data client cannot send data to data server right? I found out that only TCP communicator active.vi & passive.vi can both send and receive.
thanks,
regards,
Elsa
Message 6 of 13
(5,943 Views)
thanks,
regards,
Elsa
Message 7 of 13
(5,942 Views)
Both data and client can send and recieve.
Why don't you try modifying it, and witness it with your eyes?
Message 8 of 13
(5,925 Views)
I modified, but cannot find out the problem.
the original program can send and recieve data.
after i add the waveform chat (the file i attached is different from the original one),
it cannot work.
Message 9 of 13
(5,916 Views)
If you just say that you try, but don't attach or show anything, no one can help.
Message 10 of 13
(5,906 Views)
