TCP connection reset
Accepted by topic author smithmachine
@billko wrote:
wiebe@CARYA wrote:
Taste isn't the same for everyone, but I like my error wire straight. So it's the wire that is always perfectly horizontal.
About the only exception this rule for me is when parsing XML (or any other kind of cascading code like that).  Then I like to keep the reference wires straight and offset the nodes so my open and close references line up.
I unusually still end up straightening the error, even then. But it's in the gray zone for sure.
Message 11 of 13
(816 Views)
Double post accidently
Message 12 of 13
(807 Views)
Thanks for the help, it did clarify the LabVIEW coding part. Now I'm just left to run Unity at a higher output rate, since the HTC Vive which is linked to Unity runs best @90Hz.
Message 13 of 13
(806 Views)
